  • SN95 4.6L Mustang Tech
Coolant Issue
  • Thread starter Thread starter AmBo
  • Start date Start date Nov 7, 2005
1 of 2 Next Last
AmBo
1,027
New Jersey
Nov 7, 2005
  • Nov 7, 2005
I had my coolant fluid exchanged at Lube Express on Friday. Come Saturday my coolant light came on. I know a lot of people have problems with the floater (thanks to the wonderful "Search" button) but I checked the coolant level up front and it's about an inch below the line that reads "Add Coolant". So I'm sure it's safe to assume that they didn't put enough coolant in when they swapped it...
Now my next questions is what should I top it off with? Distilled water? More coolant?
Also, is it safe to take off that cap even though it reads "DO NOT OPEN HOT"? Can't I just let the engine completely cool down and then open it?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 7, 2005
  • Nov 7, 2005
You can add either distilled water or coolant. You should get a coolant tester to determine which would be best. Or you can just add some of one or the other, should not hurt...
You can remove the cap after the engine has cooled down for about a half hour or so. Use a rag to turn the cap just in case, the rag will protect your hand...
Also throw 1-2 bottles of Red Line water wetter in there, it works well
AmBo
1,027
New Jersey
Nov 7, 2005
  • Nov 7, 2005
Kilgore you are my hero.
Ok, so use distilled water and top it off to the "Add Coolant" line?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 7, 2005
  • Nov 7, 2005
Should be fine to add distilled water... Ideally, you want to hit a 50/50 or 60/40 mix... If you had a coolant tester you would know which to add towards that mix ratio... If not you should be ok to wing it...
AmBo
1,027
New Jersey
Nov 7, 2005
  • Nov 7, 2005
Grrr...I guess I'll just pour in some distilled water...what's the worst that could happen? :-X
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 7, 2005
  • Nov 7, 2005
Coolant tester is only a few bucks...
AmBo
1,027
New Jersey
Nov 7, 2005
  • Nov 7, 2005
Oh? Hmmmm...Maybe I'll have to go pick one of those up...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 7, 2005
  • Nov 7, 2005
http://www.bullittarchive.com/html/modules/articles/article.php?id=72
http://www.bullittarchive.com/html/modules/articles/article.php?id=20
AmBo
1,027
New Jersey
Nov 7, 2005
  • Nov 7, 2005
YOu love BullitArchive! Thanks!
DropTopPony
Noob Slayer
2,570
south jersey
Nov 7, 2005
#10
  • Nov 7, 2005
  • #10
distilled water hmmm i only use that in my humidor. For topping of coolant...the garden hose works just fine Or you could go buy some 50/50 pre-mix.
AmBo
1,027
New Jersey
Nov 7, 2005
#11
  • Nov 7, 2005
  • #11
Which would you do bro?
DropTopPony
Noob Slayer
2,570
south jersey
Nov 7, 2005
#12
  • Nov 7, 2005
  • #12
I guess if your anal you could use distilled water but do you think they have a distilled water supply at the dealership? Or do you think its faucet/hose water....just top it off with some tap water..you'll be fine.
AmBo
1,027
New Jersey
Nov 7, 2005
#13
  • Nov 7, 2005
  • #13
I was refering to water vs. 50/50 pre-mix.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 7, 2005
#14
  • Nov 7, 2005
  • #14
+1 hose water is fine...
T
TenaciousD
320
Tampa,Fl
Nov 7, 2005
#15
  • Nov 7, 2005
  • #15
yeah I have to top mine up soon, I really want to drain it and refill the whole thing but the car is too low for me to get under, I might try jacking it up from one side, letting in drain and then doing the other side to try and get it all out. I posted a thread a while ago about coolent flush but alot of people said the experienced leaks after they had it done.
40th GT
916
Lawrenceville, GA
Nov 7, 2005
#16
  • Nov 7, 2005
  • #16
Since we're on the subject of coolant, I'll ask a question here instead of making a whole new thread: Draining the radiator drains less than half of what the engine sees. I heard there is a coolant drain plug on the block? Can anyone explain?
stang217
Long Island
Nov 7, 2005
#17
  • Nov 7, 2005
  • #17
i would just top it off w/ more coolant... and as far as te do not open when hot... thats exactly what it means... when it's hot, don't open it... when the engine isn't hot u can open it
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 7, 2005
#18
  • Nov 7, 2005
  • #18
there are drain plugs on either side of the block. they are hex plugs and one is next to teh dipstick, the other is in a similar place on the other side of the block. draining the radiator does not get the crap that is stuck in the bottom of the block out. i would only really top off with water wetter if you are going to use pure water. when i build up my motor i will only run water and water wetter. im sure the track will appreciate that if god forbid i send a connecting rod through my motor in a braking zone.
AmBo
1,027
New Jersey
Nov 14, 2005
#19
  • Nov 14, 2005
  • #19
UPDATE!!!!!!****
Okay, I topped off my coolant. *DING!* Light comes on and off as it pleases...randomly...I'm beginning to think its my floater. Any other ideas?
D
Disturbed One
191
#20
  • Nov 14, 2005
  • #20
After I had my coolant exchanged out last year the coolant light would come on in the mornings when it was really cool outside for about a minute then shut off after I've drove it around. If yours is going on and off you may have an air bubble in the system they didn't get out and that's causing the light go on and off. Should take it back and ask them to purge the system just to double check and make sure all the air is out of the system.
1 of 2 Next Last
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Fox Is it time to replace the coolant?
  • PonyGTrider
  • Sep 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
AeroCoupe
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
