Well, it's been awhile since I've been here, but my car is borked. I've got a 1999 Cobra with about 60k miles on it. Today when I went to go to work I got the low coolant light, checked and had very little coolant in the reservoir. I added more, drove to work and back home, checked and my reservoir was still full, but I've got coolant all over the front bottom of the motor and the front sway bar. I suck when it comes to mechanical type things, so I'll be taking her in somewhere this weekend. Any ideas as to what the likely culprit is? How much am I looking at probably spending? Is the car safe to continue driving for the rest of the week? Until I've actually got the money to properly fix it?
Just scooch under the car with a flash light and look up at the bottom of the water pump, there will be a little weep hole, you should be able to see if water has been dribbling out of it. If it wet, then it's toast.
