  • 2.3L (N/A & Turbo) Tech
coolant leaking under waterpump
  • Thread starter Thread starter cdromce
  • Start date Start date May 10, 2009
C
cdromce
  • May 10, 2009
hey giuys need a little help here , 91 2.3l lx am at work walked out to get something from car noticed some coolant on the ground under front of engine, opened hood and seems to be a leak at bottom of water pump, hard to get a straight look at it with pulley in way this a common problem or?? not a torent
of water only a small amount and seems to be more with car running, what do you guys think water pump failing??or???
thanks
RMODEL65
313
brunswick ga
May 10, 2009
  • May 10, 2009
probably the weep hole leaking buy a new pump and put it on they are cheap
C
cdromce
  • May 10, 2009
ya know thats what i thought but i just drove it home and let it sit running for 30 min's can't get it to drop a drop ???? ever hear of one dripping then stoping??
weird
R
RustBucket
585
Buford, GA
May 10, 2009
  • May 10, 2009
The water pump (or at least the shaft seal) is failing. Go ahead and replace it now before it causes other problems.
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
