Ever since I installed the 180 degree thermostat (And my SC for that matter) when my car is parked, it spits coolant all over the ground after I run it. If I leave the overflow tank low on coolant, (where my coolant light is on) it doesn't do it. The car doesn't go above 195 degrees, either way, but I am trying to figure out what is going on. I can hear the coolant bubbling past the radiator cap (16lb) and entering the overflow. My guess is a head gasket is bad and it's letting air from the combustion chamber into the coolant system, although the coolant and oil look clean and my compression test was ok..
I did a compression test and had 125psi on all cylinders, without holding the pedal down.
