coolant problem
  • Thread starter Thread starter bluidvl
  • Start date Start date Sep 23, 2005
bluidvl
63
delaware
Sep 23, 2005
  • Sep 23, 2005
i am new to site.i have a 90lx coup converted to 5.0 car has a 75mm throtal body and 75mm mass air sensor 1"5/8 headers equeal lenth and mac cats.my problem is i keep spitting coolant out at cap what is the proper level the overflow is always full
Killer50stang
632
  • Sep 23, 2005
You're overheating! What's your temp gauge say? You want to be around 180-190 degrees. Is this a stock gauge? How old is the water pump? Radiator? Is your fan working? I'll need more info. to help.
-Poth
ss93cobra
1,422
Wilmington NC
Sep 23, 2005
  • Sep 23, 2005
Or perhaps the radiator cap is bad and needs to be replaced...
5.02GO
308
Ky, Blue Sky Country
Sep 23, 2005
  • Sep 23, 2005
Cap
bluidvl
63
delaware
Sep 23, 2005
  • Sep 23, 2005
new water pump , flex fan .it has a 16psi cap
bluidvl
63
delaware
Sep 23, 2005
  • Sep 23, 2005
temp gaufe stays about halfway it is stock
Killer50stang
632
  • Sep 24, 2005
I would replace the cap and see what happens. They go bad, but as long as you're not overheating, shouldn't be too big of a problem.
vristang
4,933
101
124
Seattle
Sep 24, 2005
  • Sep 24, 2005
Temp wise that is right where you want to be. Temps below 190 can cause increased cylinder wear.
I stay around 200 - 220F.
Sounds like the cap is bad
bluidvl
63
delaware
Sep 25, 2005
  • Sep 25, 2005
coolant
thanx for the input guys replaced the cap and watched it turns out i had a lot of air in the system but bled it all out .the leak was in the line comeing from the overflow .fixed it
Killer50stang
632
#10
  • Sep 25, 2005
  • #10
220? You're nearly boiling over at that temp...
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 25, 2005
#11
  • Sep 25, 2005
  • #11
Though 220 is a little high it's not critical just yet, I would not want to see it very often but not considered overheating yet.
Killer50stang
632
#12
  • Sep 25, 2005
  • #12
true, but usually when I've seen 220, it doesn't stop there...
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Sep 25, 2005
#13
  • Sep 25, 2005
  • #13
Oh that can be very true..you really do start to fixate on the gauges when you in that area. I will admit I would be looking to shut her down at 220 with aluminum heads..just in case.
Killer50stang
632
#14
  • Sep 26, 2005
  • #14
yeah, I had aluminum heads on mine when mine was running hot...I was affraid of a warpped head. Now I'm running TWO electric fans. One in front of my radiator and one on the back. Those ZIRGO fans on ebay are amazing!!
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
