Coolant Problem
1.8kmint
47
Middletown, CA
Ok i just filled the coolant about a month ago. And now the car is saying low coolant again. It has lost some coolant when i check (not alot maybe a few pints) it but there are no apparent leaks. I also know its not the head gasket because it was just replaced 2 months ago. I'm wondering what is normal for coolant consumption? Also since the coolant overflow is not airtight at the top could this have something to do with losing coolant. Where I live now its between 95-120 every day. Also sometimes the light goes off after I drive it for a while and it never runs hot so I'm wondering if this is normal.
Get a coolant pressure tester and put it on your radiator, pump it up and wait like 10 minutes, look on the ground and all along the engine bay and engine bay itself. Suprisingly you will find a leak, especialy since the coolant system is pressurized with that tool. Thats how I find most of my leaks, I have seen parts leak that you would never think was leaking but it ended up leaking. :)
Try that and see if you find it.
