Coolant Smell
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Nov 18, 2007
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Nov 18, 2007
  • Nov 18, 2007
when i turn the heat on you can sort of smell coolant. still blows hot, but sometimes if i put the defrost on the windshield it will start to fog a little. is it my heater core?
cobradvm
245
Woodinville, WA
Nov 18, 2007
  • Nov 18, 2007
sounds very much like it - check and see if you can feel any damp carpet below it.
90blacknight
136
Nov 18, 2007
  • Nov 18, 2007
Check the weep hole under the hood on passenger side of the firewall. If you see coolant coming out then it's time to change out the core.
SuperStang83
1,693
Boyertown, Pa
Nov 18, 2007
  • Nov 18, 2007
Yep, it is a lot easier to change than you would think though.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Nov 18, 2007
  • Nov 18, 2007
terrific, thanks guys
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
Engine Retorque lower intake manifold bolts
  • 91GTstroked
  • Sep 8, 2025
Fox 5.0 Mustang Tech Sep 8, 2025
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
