Cooling Help, overflows
I recently installed a 4 row radiator on my 289. It gets hot but doesnt overheat. I have noticed that it overflows the radiator everytime i drive it. I just have a line going to under the car so it dumps on the ground. Is there supposed to be a tank that is pressurized?
What is weird is that i will have it running for a while and then shut it off and after a few minutes i can hear what sounds like a loud gurgle in the radiator and thats when the fluid seems to come out also. Im sick of refilling it everytime i drive it. There are no leaks and everything is new on it.
thanks
definately get a 16lb. cap with a new radiator. the 13lb one wont hold nearly as well. the problem with a downflow radiator is that the really hot water returning from the engine enters at the top of the radiator right where the cap is, which increases the boilover potential, unlike a crossflow radiator where the water around the cap has usually been through the radiator already. the 16lb cap will increase the boiling point of the water, minimizing the chance of it overflowing. also, i got a recirc. can to catch and recycle the flow.
It's normal for some coolent to come out the top. The coolent expands as temperature increases.
Install a coolent overflow tank. That's what they are made for. Or just leave some empty space in the radiator. Then it only vents air.
Getting a higher pressure cap won't do much for this sort of thing. Higher pressure caps only help if your spilling your coolent because it's boiling over.
notny41 said:
Fill with mostly antifreeze and less water mix. That will raise the boiling point of the coolant.
I'd never run more than 50% anti-freeze/coolant.
Correct, anti-freeze/coolant is used mainly for lubrication and keeping your water from freezing.
Since I dont live where it gets under 40*, I dont use anti-freeze. I use 100% distilled water, anti corrosion additive, and 1 bottle of water wetter. water is the best coolant
scottthomp said:
yes the coolant is frothy, if i drive it hard for a short period it gets hot, but the coolant that comes out is not too hot cuz i can touch it. yet the upper and lower radiator hoses are very hot.
i wouldnt suspect a head gasket just yet,sometimes the water pump impellar can airate the water cuasing cavitation and make bubbles.
Here's a really cool trick an old-timer taught me.
Disclaimer! I've never had the chance to try it yet, so I don't know if it works. But I can't see why not!
Basically I was told to wait until the engine is cold, then pull off the radiator cap. Place a balloon (condom may work better) over the filler. Slide the balloon over the vent spout or block the vent hose/spout.
Now start the engine and let it idle for a couple of minutes. If you see the balloon inflate then you have a head gasket leak. Keep in mind, that the balloon will inflate as the coolent gets hot even if there is no headgasket leak. So the idea is to only run this test until the coolent starts to get warm.
