Been putting some miles on the car today and noticed that with the 180 stat she kept 180 to under 190 all day in traffic..highest point was parked in the driveway after I got back for 10 minutes, gauge reached 190-193 range. Now after pulling into the garage and shutting down the wife asked me to run to the store. Now when I fired her back up (two minutes after I had come back the first time) the temp was 200's..which I attribute to heat soak after shut down..no problem. Now the issue is the car was not able to get the temp back into the 180's again..even after some good time behind the wheel (far past the store
) she held solid 195 to just under 200 all day wether cruise or idle. Now the conclusion I'm coming to is my stock old rad is able to keep up with the temps when they come up, but unable to disapate enough heat to actually get the temps back down once they get up. That has me thinking a new 3 core is in order..likely brass (cheaper and available)...is my thinking reasonable? Water pump is Eddy high flow and new..hoses new...Tstat 180 is new and seems to be holding well...clutch fan and fan are new...rad is OLD calcium filled but has held up till now. Just for info..weathe today 85 and 55 percent humidity..hot but not crazy hot yet.
