I've had a cooling issue for 3 years now. I installed a manual high speed switch on it as a temporary band-aid. Now I want it really fixed. And before you suggest it, yes, I've spent hours reading the forums about this.
Symptoms:
1) Gets way too hot at idle or around town driving.
2) Highway driving is just fine, nice and cool.
3) Fan doesn't kick on, at all. At temps. I've read up to 217 degrees without seeing the low fan kick on.
4) Using a code reader, the system cycles the low speed and high speed fans fine.
Attempted fixes:
1) 180 degree stat.
2) Huge alum. radiator
3) New rad. cap.
4) ECT sensor replaced.
5) High speed manual switch (works, but sick of it)
6) System burped of air in the lines.
So given all that: What is up with the fan not coming on? The ECT is brand new. The manual switch fires up the fan just fine. And the ECU diagnostics cycle through low and high speeds while pulling codes.
Thanks!
Symptoms:
Attempted fixes:
1) 180 degree stat.
3) New rad. cap.
Thanks!
