This issue is regarding my Dart Iron Eagle 347. I got it running a few months ago and haven't really driven it that much after I raced it. But I noticed when I was racing it that it would get hot at the end of a pass. I had a 180 thermostat in it and it would climb to 190-195 at the end of a pass.
Today I changed the thermostat to a 160, and it was seemingly fine (running around 160 deg) 'til I shut it off at the gas station and it heat soaked to 195 while it was off. I fired it, drove it, and it only recovered to 180 degrees while cruising at about 45 mph. Then it slowly started climbing temp.
I just put a brand new Motorsport radiator in it, the new thermostat today, and the water pump is an Edelbrock (new with the motor a few months ago). It has a black magic fan. No condenser in front of the rad.
I have a couple ideas, but I don't know how feasible they are....
1. I don't have that plastic valence under the front bumper anymore... maybe the air isn't being directed correctly through the radiator.
2. Maybe I need to route the water to a different spot on the intake (this is the Spyder EFI intake). I routed it as similarly to stock as a I could without the heater core pipes. The two lines from the pump go to the same place on the intake. Could this be incorrect for a carbed intake? How are they run on a carbed engine?
3. Maybe this engine just runs hot...
ANY IDEAS?
ANY IDEAS?
