Cooling problems
  • Thread starter Thread starter 1fast95stang
  • Start date Start date Aug 3, 2008
1fast95stang
52
  • Aug 3, 2008
I have a 95 mustang GT with a procharger. Went out for a little fun on a real curvy road got done and noticed some oil was coming out of my valve covers and dripping on the headers. Ok so park it going to tighting the bolts back down. Wait about 3 hours for it to cool off. Come back out and all my cooling lines are sucked together. Like there was a huge vaccum. So i pop the raidator cap, and inside it is a bunch of junk. Looks like dirt or very small pieces of a gasket. Checked the oil thinking if i found coolant in there then it was a head gasket and nothing. just oil. No coolant leaked after i parked my car. And its still full so if i did lose some it wasnt much at all. Anyone every seen anything like that inside the coolant. or seen the coolant hoses all sucked together.
putnam88
102
tavares
Aug 3, 2008
  • Aug 3, 2008
well ur coolant lines being sucked together believe it or not is a huge sign of a bad radiator cap. sounds strange but a cap dose more then you would thing, when ur car heats up pressure builds and pushes extra coolant out into your over flow tank but there is a valve that works for when ur car is off and sitting it cools then there is a vaccum from ur engine sucking water back into the engine so try a diff cap c if that fixes is but about the gasked in your coolant no clue only guy thermostat houseing ?
1fast95stang
52
  • Aug 3, 2008
Thanks i will get a new cap and see if that takes care of it. I think that the junk that was in my radiator fluid might have clogged up the spring to the radiator cap. I dont know where it came from. just did a flush about 500 miles ago. hope i can figure it out.
putnam88
102
tavares
Aug 4, 2008
  • Aug 4, 2008
good luck
MarcMonteverde
66
S@c-ToWn
Aug 4, 2008
  • Aug 4, 2008
well after reading ur post, id say get a new cap like the previous person said
watch ur oil , coolant in the oil, is a blown headgasket, but if theres gasket or dirt in the coolant, do a coolant system flush, see whats actually in there, that way u know for sure, than pop off ur lower coolant hose and take a look at it, sometimes the hose's break down inside.
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
