Cooling problems
SmokyJoe
10
tulsa ok
Hello, i have a 94 Cobra and the fans quit working.I went to check the CCRM plug 12,24 for voltage and they were ok.The strange thing is, i had loosened the bolt on top of the CCRM and as i re tightened it the fan would come on then go back off as i further tighten the bolt.I do hear what seems to be the relays kicking on and off as i tighten the bolt.Any info would be great.
Sounds like a bad connection and/or a broken connector that is affected with the tightening of the mounting bolt. A visual inspection and cleaning of the connectors (electrical contact cleaner) may help or identify the problem.
