cooling problems
  • Thread starter Thread starter stang9150
  • Start date Start date Mar 15, 2011
stang9150
142
Mar 15, 2011
  • Mar 15, 2011
1 month ago I installed a set of Contour fans and a dcc controller.Since then when I first drive my car in the morning the temp gauge will shoot up past 230 then come back down like the t-stat is sticking closed,(180 t-Stat).I changed out the thermostat 2 weekends ago and it was working fine until this morning.Did the same thing again.The system is sealed with no leaks and there is no air in the system so not sure what is causing this.This never happened with the clutch fan.
Beasty306GT
671
Oxford,Mass
Mar 15, 2011
  • Mar 15, 2011
are you sure it is wired correctly
4rdnut
188
  • Mar 15, 2011
fan turn on temperature
What is your fan turn on temperature set at. A 180 degree thermostat won't fully open until 188 degrees, i have tested them in boiling water. Then you want to set the fan to turn on at 10 degrees above 188 degrees so your not fighting the opening and closing of the thermostat, try 198 degrees fan turn on at the controller and see how it works. When the fan kicks on it will cool down 8-10 degrees until it stabilizes at 198. I have my fan set this way and the temp gauge will stay at 198 degrees no matter how hot it is outside in traffic. I also have a mechanical water gauge, i don't trust electrical gauges.
stang9150
142
Mar 15, 2011
  • Mar 15, 2011
The fan controller is wired up per the instructions and work fine after the first start up of the day.When the temperature goes up its not a slow movement like the car is overheating with the fans on,just a very rapid temp rise.When I shut the car off and turn it back on the temp returns to 180 almost instantly.I had a Mark8 fan installed with my factory overflow tank and everything was fine.I wanted more room so switched to these fans with the generic advance auto parts overflow tank and now having this issue.
4rdnut
188
  • Mar 15, 2011
See if the upper radiator hose is hot when your temp gauge hits 190-200 degrees, if not you may have put the thermostat in backwards.
stang9150
142
Mar 15, 2011
  • Mar 15, 2011
After the thermostat change it ran fine for a little over a week.I imagine a backwards t-stat would show as a problem right from the get go.
4rdnut
188
  • Mar 15, 2011
I would take the thermostat out and put it in a small pot of water and heat it up and check it with a meat thermometer. I have seen stranger coincidences with my car, maybe the new thermostat is defective.
Dino Dino Bambino
1,673
90
79
Cyprus
Mar 15, 2011
  • Mar 15, 2011
Exactly what I'm thinking.
stang9150
142
Mar 15, 2011
  • Mar 15, 2011
Going to go ahead and replace the t stat tonight and see what it does,god I hate that by pass hose!
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Mar 15, 2011
#10
  • Mar 15, 2011
  • #10
Try the mr. gaskets 180 thermostat, i like them alot better than the stant style.
Should be available at pepboys or autozone.
The sudden rise suggests the problem has nothing to do with the fan.
It almost has to be the thermostat or air pockets.
4rdnut
188
#11
  • Mar 16, 2011
  • #11
Make sure you put the thermostat in the housing first, it has to sit in the recessed area, so clean that out too, then put the gasket over the thermostat. I use high tack on the housing side of the gasket to hold the thermostat in the housing while bolting to intake. The intake side of gasket i put a light coating of anti seize compound so later down the road the housing will come off easy and you can reuse the gasket. Also pointed end of thermostat towards radiator and copper pellet end toward intake.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
V
Cooling fan low speed not turning on
  • vman
  • Feb 27, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 24, 2025
vman
V
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
