  • 2005 - 2009 Specific Tech
Cooling system Question
  • Thread starter Thread starter GOLDENPONY
  • Start date Start date Sep 26, 2008
GOLDENPONY
1,503
LOVELAND, OHIO
Sep 26, 2008
  • Sep 26, 2008
Anybody done a drain & flush of the cooling system? Does the 4.6 block have block drain plugs? A local shop I trust charges $109 (includes coolant). I wonder if it's worth doing myself or have them do it. They install Zerex G-50 (gold) which meets the Ford spec. Thoughts?
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Sep 26, 2008
  • Sep 26, 2008
are they hooking up a machine and flushing the system with pressure, or just draining and refilling? many shops will make a shortcut, but you said they are trustworthy. If you dont have a way to flush the system out at home, i say take it in. i am not sure if we have block drain plugs or not, but knowing ford, i would say no.
anthony05gt
1,262
Maryland
Sep 27, 2008
  • Sep 27, 2008
Since the car's only a couple of years old (mine's 4 years) I just drained the radiator and disconnected the lower hose from the engine. It's not like you'll be draining an old corroded system. If you change out the coolant every 2-3 years that's all that's needed along with a bottle or 2 of water wetter. I live in Maryland, my garage still gets cold at night so I went with a 60-40 mix (mostly watter) and 2 bottles of watter wetter. With that mix my maximum temps in the summer are about 8-10 degrees lower than before.
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
