Correct way to adjust valves?
  • Thread starter Thread starter 1bad92lx
  • Start date Start date Feb 13, 2004
1bad92lx
247
Close to lynchburg, VA
Feb 13, 2004
  • Feb 13, 2004
I've got a set of stud mount harland sharp rr's. I floated the valves a while back and since I'm using chromoly pushrods the rockers were knocked out of adjustment instead of bending the pushrods. I've took all the pushrods out and checked them just in case and put them back in and set the rockers on too. I'm wondering what's the best way to adjust them. I'm thinking of turning the motor over by hand and setting them at 1/4 of a turn past 0 lash. Does this sound right? Am I on the right track or am I way off? I was going to get the shop that put the motor together to adjust them, but they are backed up for a few weeks so I figured I would try it myself.
thanks
W
wildstang347
83
  • Feb 13, 2004
set them no less then 1/2 turn past 0 lash and stay around 3/4 max, going 1 cyl. at a time turning by hand should get you in the ballpark.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 13, 2004
  • Feb 13, 2004
See http://www.trickflow.com/product/twisted_wedge/info_pages/twiswedge_inst_frame.htm for help with stud mounted rocker adjustment
C
chevyeater
438
  • Feb 13, 2004
haven't ever seen rockers go out of alignment from floating valves. usually bent pushrods or bent valves. so if pushrods are ok then may be the valves that caused the adjustment to be off.
ashford
485
fargo ND
Feb 13, 2004
  • Feb 13, 2004
what are you useing for an alignment setup? pushrod guides or rail type rockers? the pedastal mount are aligned by the mounts, studs need pushrod guides or rail type rockers
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
