Could my Fuel pump be on it's way out?
Haus
408
I've been having intermittent problems with my power out put with my 92 5.0
feels like its starving for fuel at times. especially when the tank gets below a 1/4 of a tank. once in a while it will make the sound you hear when you run out of gas.
Could the fuel pump be sucking in air and into the fuel lines and making my FP low and leaning out??
FYI my filler neck grommet is shot(doesnt leak but reeks of fuel inside my car when i get more then 1/2 a tank of gas) so could that be allowing air into the tank and causing my fuel pump to suck in air if this is the case.
If it happens more when you are corning or accelerating (when the weight of the car shifts) if could be the tub inside the tank.
I had a tub break loose in mine, so if i was low on gas and stepped on it or tore around a corner the car would starve itself.
Only cure was a nother tank.
If you aren't familar with the tub, it's a thing that looks like a bath tub that the fuel pump sock sits in, so does the filler neck, so when you put gas in the car it's the first place to get fuel, and the last place to have any left.
It's welded to the bottom of the tank and can break loose.
Now, realistically if you think this is the problem, you might as well change the pump too while you are at it.
well the fuel pump is 3 years old so i wouldnt replace it unless i had to.
i feel the hesitation and studdering at lower RPM's( around 1000) when i have about a 1/4 tank left. when i step on it, it's fine for the most part
i got to change the grommet so ill take out the tank and check everything out.
when i hear the pump cavitating and is sucking air in the fuel lines is when i start to have problems.
but if i would stop somewhere, turn of my car, then go to start it again and prime the pump its fine for a mile or so then does it again.
Is your fuel pump extremely loud? I know my filler neck grommet is shot because when I fill it it leaks out, and my fuel pump is superrrrr loud. I can hear it standing like ten feet away from the car.. All I've done is put in a walbro 255 pump in and the thing is so loud.
