Could this cause a bad vibration?
  • Thread starter Thread starter Kdubslugga
  • Start date Start date Sep 4, 2006
Kdubslugga
1,515
Akron, OH
Sep 4, 2006
  • Sep 4, 2006
Ok so heres the deal a few weeks ago my oil pump broke i pulled the engine and put a high volume pump, ARP oil pump driveshaft, new oil pan, timing chain and some Prothane Polyurethane motor mounts on. Ive been driving my car and there is a vibration that wasnt there before. I can feel it in my seat when the RPMs are between 3-4k. I replaced the Harmonic Balancer with a Ford Racing Unit, that didnt do a thing so i got underneath the car took the motor mount bolts off and the passenger side stud on the motor mount is sitting nice a flush with the slot in the K-member, however on the drivers side it is not on the bottom of the slot, the stud stops like a centimeter before it touches the bottom.... Could this be my vibration? My driveshaft is a Ford Racing aluminum and is about 3 years old, could it just be the mounts or what? Its not a horrible vibration but its enough to shake my rear view mirror and make everything blurry in it..
04sleeper
2,674
14
89
Dallas, TX
Sep 4, 2006
  • Sep 4, 2006
Are you sure that nothing is touching or rubbing?
Like headers or such? Or could it have moved the tranny in a different way?
Kdubslugga
1,515
Akron, OH
Sep 4, 2006
  • Sep 4, 2006
Im not sure of anything, lol.
04sleeper
2,674
14
89
Dallas, TX
Sep 4, 2006
  • Sep 4, 2006
I know that the Prothane bushings are stiffer than stock.
Could it be possible that now you are feeling a vibration that has always been there?
Kdubslugga
1,515
Akron, OH
Sep 4, 2006
  • Sep 4, 2006
It very well could be, I dont know if im just paranoid or what.
04sleeper
2,674
14
89
Dallas, TX
Sep 4, 2006
  • Sep 4, 2006
After going through as many oil pumps and shafts as you did, I would be very astue to what noises and vibrations are coming from your engine.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Sep 4, 2006
  • Sep 4, 2006
How many miles are on your driveshaft? I just replaced the U-joints in mine, and at 200k all the bearings in one U-joint were rusty powder. This caused the compainion flange to be very stiff and hard to move. It would cause the whole car to vibrate pretty bad, it was so bad I could hear it. Replaced them today and now its smooth as glass. The only good way to check this is to pull the drive shaft off.
Kdubslugga
1,515
Akron, OH
Sep 4, 2006
  • Sep 4, 2006
driveshaft has less than 6k miles on it. Im gonna take it off and turn it 180 degrees over, i read that over on Ford Muscle.com I guess it wont hurt to try.
Kdubslugga
1,515
Akron, OH
Sep 4, 2006
  • Sep 4, 2006
I dont think its anything to do with the engine cause it doesnt do it Neutral, granted there is little vibration but not like it is when im out on the road at a higher RPM.
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Sep 4, 2006
#10
  • Sep 4, 2006
  • #10
A U-joint could still be bad, if any of the seals have a defect or if water got in, it doesn't take very long at all to sling the grease out and burn up the bearings. If your going to pull out the driveshaft its worth checking. I dont think turing the driveshaft 180 degrees will change anything, I've had mine both ways and it made no noticable difference.
M
mike0227
53
Houston Texas
Dec 3, 2006
#11
  • Dec 3, 2006
  • #11
kdubslugga did you find out the problem? Mine does the same thing and I
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
