Well my car has a problem with running hot. This problem originated about a year ago when I swapped on some BBK LTs, a Dr. Gas offroad x-pipe, some new plugs and wires, and an ASP smog pump eliminator kit. Before these mods the car ran fine temp wise (yes I have pullies but had had them on the car for a year before this stuff had been put on), but as soon as I started to drive the car with the new stuff, it would run really hot, like even hitting the A and L on the gauge while on the highway. Now I posted about this several weeks ago and another member suggested that I swap the plugs I had for ones that were one heat range colder. I had Autolite 25s and went to 24s. This helped the problem, it made it take longer to heat up, but engine still gets to the A on the gauge.
Now I had the timing increased to 14* probably 6 months before I had swapped all that other stuff on, so the car still had the original plugs and wires on it. Could this be too much timing? Should I try bringing the timing down a couple of degrees? The engine wont ping until the temp gauge is way up there. Its hard to hear with my exhaust but I can hear it.
The engine will only get hot when it is under a load, so if it sits there and idles, the temp needle will stay around the O or so.
If anyone has any other ideas please chime in. I do plan on getting a Fluidyne and a Stewart waterpump so hopefully that will get rid of the problem totally if the timing thing doesnt work.
. But I guess Ill have my timing lowered a couple of degrees and see if that helps.
