hi!! Im going drag racing in 2 weeks and just have a couple questions, here is everything I have done to the car: 14.2 @ 93 mph last yr just gears and slicks basically this yr i have all these things done to it plus the nitrous, just curious how deep into the 12s i can make it:
-Edelbrock Performer 5.0 Intake
-BBK 70mm throttle body and egr spacer
-C&L 76mm maf sensor
-Walbro 255lph high flow fuel pump
-Ford Racing King Cobra clutch
-Ford Racing heavy duty upper control arms and bbk lowers
-373 gears
-Flex-a-lite fan
-BBK 1 5/8" Long tube headers with 2.5" h pipe and super 40 dumps
-Holley adj fp regulator
-Cold Fusion Nitrous Wet Kit adjustable to 175hp
-Solid motor mounts and poly tranny mount
-Mac diff girdle, subframe connectors
-Comp cams double roller riming chain
-High flow water pump
-Underdrive pulleys(stock alternator pulley used)
-BBK adjustable clutch cable w/ firewall adjuster
-AC/Smog pump delete
-MSD tfi blaster coil and frpp 9mm plug wires
-High torque mini starter
-BBK cold air intake(fenderwell)
-et drag slicks 26 x 8.5 x 15
im set up pretty nice to run a 100 shot maybe more, what plugs should I be using and what gap size? I herd 1 step colder plug but i need some part #s and what gap??
also im just wonderin if i should be buying some 90/10 drag shocks and remove front sway bar or not to bother, i wanna buy a few other things to try and pick up the car a couple more tenths, alum driveshaft?
I have a few chevy guys i hafta go faster than this yr so i know if i run a high 11 or low 12 ill have a pretty good chance of beating em.
any input welcomed
thanks adam
-373 gears
-Flex-a-lite fan
any input welcomed
thanks adam
