OK...so I am replacing my trans with a used Tremec 3550. Should i got with a Steel or Aluminum bellhousing? Also, I will be replacing the throwout bearing...is it the same on for the 3550 as it is for the t5? Last question is will the tail shaft seal for a t5 work on a 3550?
Thanks!!
Danny
Thanks!!
Danny
Keep in mind, the scattershield requires a lot more work to put in than a regular aluminum beel. The throw out bearing and pilot bearing are the same but make sure you replace them while you are there.
