Couple Quick Questions
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
ok so im about to purchase a 2000 stage 2 roush. i need to replace the driver side mirror, so the first question would be, how do i get the old one off? someone kicked it off and its currently being held on by ducktape. also, it doesnt have cats on it, and ill need them to pass inspection. does anyone know if a h-pipe of a mach will work on this? thanks
The mirror is bolted behind the Mach tweeter speaker (if equiped). Remove that and then there should be two bolts/studs holding it on.
I have no clue on the mid pipe. I would imagine the mach uses the same as the cobra. Not sure if they are interchangeable or not.
The cover on the tweet pops off (carefully) and iirc there are screws holding the rest of the assmbly on. Remove those and you'll get to your mirror. Good mach 460 speaker replacement. There are a few good write ups on it with good pics out there.
You will have to remove the door panels, then take off the mach460 tweeter...then unbolt the mirror...pretty simple.
As for the midpipe...considering the Mach engine is a 4v, I don't know if the midpipe would bolt up to the Roush's headers?
Why not just find a regular GT midpipe?
