couple ?s
95silvergt5.0
113
so my pilot bearing breaks 2 pullers...I decided to just grind it out. This works fine except for I now have 2 notches around where the bearing was(end of crankshaft) I have my bearing in the freezer 2 make it easy 4 install tommorow but im wondering if it will sit right??? also how much is it to make a key if you dont have a key to copy from :bang:
The crank got cut? Uh oh.
I had a new set of keys made for a car (only came with the valet key). I brought the locksmith the master lock (pass door lock - the locksmith provided that info to me. This was on another car and is not right for your stang).
Then he made me a couple keys and charged me 20 bucks. Cool with me!
next time you remove one use a snap on, or mac remover. never had a problem with one. as far as the gouges go, just hope they are not deep, but dont sand them down, or you will be in worse shape. you can use high temp jb weld in them after you clean the area with brake parts cleaner.
