Crane Hi-6s Ignition & Lx-91 Coil users???
cjhenry01
43
What are you guys running for a plug gap with this ignition setup? Also, what plugs are you running? I read in the ignition instructions that you should not use copper core wires but can I use copper core spark plugs? I just bought Autolite 25 Copper Core plugs & would like to use them. Should I return them?
My new setup will be the following:
Crane Lx-91 Coil
Performance Distributors 5.0 Livewires
Performance Distributors Dyno-Mod (TFI Module)
What do you guy's recommend for my plug gap?
The Autolite plugs are fine--they just don't want you running solid core ignition wires. As for gap, unless you're running a power adder, I'd recommend just staying with the stock gap as it's pretty wide as is. With a power adder, you'd probably want to close it down--even with the aftermarket ignition.
