  • 1994 - 1995 Specific Tech
CRANK HARD TO TURN ??
  • Thread starter Thread starter howiefisher
  • Start date Start date May 18, 2008
First Prev 2 of 2
howiefisher
154
Ont Canada
May 21, 2008
#21
  • May 21, 2008
  • #21
cost me $1400 FOR THE LONG BLOCK it has warrenty what should i do like i said i had a full battry and a booster pack on and it would barly turn ...it might of cranked 20 times in 4 stages would not fire though am assumign the timing was way off the book said to take the hb to 0 did that and point the rotor at #1 cylinder and i had the #1 piston at tdc on its compresson sroke .no fire all i could smell was gas ,should i of put the hb at 10 so it would of fired
HISSIN50
34
129
May 21, 2008
#22
  • May 21, 2008
  • #22
If it doesnt want to crank, dont even bother with ignition timing.
If you have it on a stand and it doesnt want to turn over with a breaker (or is too tight and noisy, and the noise has nothing to do with any accessories or components not apart of the long block), now is the time to contact the vendor/manufacturer and get their input.
howiefisher
154
Ont Canada
May 21, 2008
#23
  • May 21, 2008
  • #23
this thing is like a week old i would hoope they give me a new one my car has be down for liike a month i need it bad ...i ment to set the timing to 10 on the new motor when i go to start it ?
Adam95GT
2,564
Burlington, NJ
May 22, 2008
#24
  • May 22, 2008
  • #24
had a problem with mine when we were building it. pull out the ditsy then try to crank it. for some reason the ditsy/ oil pump drive were causing binding
desertcox05
379
south atlanta
May 22, 2008
#25
  • May 22, 2008
  • #25
maybe the timing chain and tensioner is fubar the dizzy sounds like a good place to ck too
howiefisher
154
Ont Canada
May 22, 2008
#26
  • May 22, 2008
  • #26
well i am takin the motor back tomarrow they have a new one for me but trhey want to inspect the motor first ?any body have a ny ideas what might of happend like i said it has neverd fired and was well primed only cranked 20 times then seized ?feels like crank bearing to me ????
Adam95GT
2,564
Burlington, NJ
May 22, 2008
#27
  • May 22, 2008
  • #27
Recheck what people said and im sure you will find your answer.
C
cbarr300
746
goose creek, SC
May 22, 2008
#28
  • May 22, 2008
  • #28
the only thing you can really do is turn it over as much as you can and inspect parts to see if anything seems out of place. Perhaps someone put a super torquing on you main caps? I don't think that'd cause your problems. Only way to know for sure is to tear it down if nothing seems obvious up front
reddy351
560
12
38
Columbus, Ohio
May 23, 2008
#29
  • May 23, 2008
  • #29
He's got a warranty on it. Prolly not a good idea to take it apart.
First Prev 2 of 2
1995 5.0 just cranks
  • 9GT5
  • Jun 29, 2025
1994 - 1995 Specific Tech Jun 29, 2025
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
