Crankshaft Oil Slinger - Do I need it???
LONN17
135
Oceanport, NJ
With my double roller timing set the crank oil slinger does not fit between the crank timing gear and the timing chain cover. In this situation do I omit this part or are there thinner versions available?
Thanks
Trevor
I accidentally left the oil slinger out of my 250 straight six when I rebuilt it. It didn't leak the first year, but some time during the second summer after the rebuild it started leaking. I was too lazy to tear everything apart to fix it, so I just drove it. The leak was never so much that I would run low on oil between changes, but it was ugly on the motor. I ran it for 8 years before I decided to pull it in favor of a 302, but the oil leak was never more than an annoyance.
.. your results may vary.. :D
Thanks for the info guys. I did a search too and found pretty much the same answers. Its together now and I will see how it is. If it begins to leak too bad I will just have to switch back to a standard timing set. Its easy enough to replace in a year or so if warranted.
Trevor
