After doing a lot of research (Thanks to 'Stangnet gurus) on rebuilding my low compression '74 block and mismatched '66 heads, I started looking into crate engines. (Ford Racing FMS-M-6007-XE3M) I realized all the machine work, checking, parts, assembly, time, peace of mind and cost exceed the effort of putting in an engine already put together.
1. If I get a newer style roller motor (50oz imbalance) and keep my C-4, I need a 50 oz, 157 tooth flexpate, right? Is there a difference between a flexplate for a one piece seal and a flexplate for a two peice seal? Spacing or bolt pattern? Part number anyone? Source? I know there are a lot on internet sales places, but I couldn't find the info I was looking for.
The crate motor comes with the reverse flow timing cover, "short style" waterpump and damper with (I assume) the short style pulley. This would be great, beacause of my short distance to my Taurus fan setup.
2. Would I be able to get the rest of the serpentine setup off an Explorer or certain year Mustangs? Anyone running the "short style" serpentine setup?
I need a Steel Gear on my MSD distributor. MSD recommends I send it to them with a gear I buy somewhere else???$$$.
3. Anyone change theirs? What did you do?
4. The timing cover doesn't have a fuel pump boss, so I'll have to get an electric pump. Any suggestions?
Thanks
Thanks
