Crazy overheating problem
  • Thread starter Thread starter my93gtdroptop
  • Start date Start date Jul 14, 2005
M
my93gtdroptop
  • Jul 14, 2005
I hope some of you cooling experts can help me. I have fought with overheating problems on my 93 GT convertible for as long as I an remember. I did a bunch of work to it recently, and really tried to address the overheating. It has a beefed up custom AOD with a precision industries 2800 stall converter. I added two trans coolers. I also added an engine oil cooler. I installed a Meziere 55 GPM electric water pump. I added 4 electric fans that cover the entire radiator. Together they pull around 5000 cfm. I wrapped the headers in thermotec header wrap. I installed a new front fascia with more airflow through it. 6 or 7 years ago I put in an aluminum radiator (can't remember the specs on it). I figured it should be ok, so I left it. During all this I also upgraded to a vortech T-trim, put in a professional products upper and lower intake, and a new fuel system.
I took it out yesterday for the first time and within 5-10 minutes it was at 260 degrees (on the factory gauge). I know I need an aftermarket gauge, but it was really hot. Waves of I heat were coming through the firewall and over the top of the car. It was 107 degrees outside and the air off the engine was still cooking me. I am really frustrated. I am now thinking the radiator since I have nothing else to replace. But, the kicker is that I can turn on the electric water pump and 4 fans with the car off, and it will cool the engine down 100 degrees in less than 5 minutes. So, it seems like the cooling system can work. The A/C condenser is pretty banged up, and the A/C system is a whole issue to itself, so I thought that may be restricting the air to the radiator. But, like I said, when the engine is off it will really cool the car. Also, the car has a 160 degree thermostat, and I can let it idle in the 107 degree heat, and it won't get above around 160. But then I start driving it and watch the gauge just climb to the top.
I have spent so much money and energy on the car, and now I am out of both. I really love the car, and want to be able to drive her. Is it the radiator? Any ideas are welcomed. I hope you guys can help me out.
Black Sun 5.0
1,337
L.I., N.Y.
Jul 14, 2005
  • Jul 14, 2005
Is the car heating up while cruising or in idle? Do you have the radiator air dam installed? That solved all my temp issues. Get an aftermarket gauge. Are you boiling over?
M
my93gtdroptop
  • Jul 14, 2005
Hey Black Sun. The car seems to be fine, and run cool while idling. As soon as I start drving it, it heats up. I am not familiar with the radiator air dam. What is that? I will work on getting an aftermarket gauge when I get some cash. It is not boiling over. I try to shut it down before that happens. I don't want to hurt my engine. It does seem to vapor lock when it gets to the top of the stock gauge. Thanks for the help!
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 14, 2005
  • Jul 14, 2005
My Factory gauge will read 260 degrees after about 5-10 mintues of driving, but my Autometer reads 180.... GET AN AFTERMARKET GAUGE! If you can afford a T-trim, you can afford to spend some money on GOOD gauges
DTT92LX
185
Downingtown, PA
Jul 14, 2005
  • Jul 14, 2005
Gotta be the gauge. With all the cooling mechanisms you have in place and your obvious stress and concern over the temp, you have to get the right tool to evaluate it!
Black Sun 5.0
1,337
L.I., N.Y.
Jul 14, 2005
  • Jul 14, 2005
The air dam is the black plastic strip mounted right beneath the radiator that forces air up through the radiator while you're cruising. I didn't have the air dam and had issues. I have an SN/95 electric fan installed with a DCC managing its power. Even with this setup, the fan would run while cruising on the highway and I would get inconsistent to high temps (even with a Fluidyne aluminum radiator). I installed the air dam that I got from 50resto.com for about $30, I haven't had a cooling problem since.
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Jul 14, 2005
  • Jul 14, 2005
If the gauge is good and there really is overheating, check for air in the system, especially if it heats up that quick.
M
meze1111
44
  • Jul 14, 2005
I think you might have a small leak in your head gasket. maybe its overheating from building up pressure. Check your oil for coolant. How many miles on the car?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 14, 2005
  • Jul 14, 2005
Good point, a blown head gasket, or cracked block/head will make an engine heat up real hot, real quick. Cylinder pressures are higher when the vehicle is under load. Use a hydrocarbon detector (block test kit) to see if there is any exaust in the cooling system.
If your feeling that much heat comming off the radiator, then the cooliing system is working, but could be overloaded by other issues. What was the temps comming out of the water outlet? The factory gauge sucks.
HISSIN50
34
129
Jul 14, 2005
#10
  • Jul 14, 2005
  • #10
Are you sure your elec water pump is coming on?
It was 107 here yesterday also (Tucson) so I feel your pain. 30 straight days of triple digit heat so far.
Good luck.
M
my93gtdroptop
#11
  • Jul 15, 2005
  • #11
Great replys. Thanks everyone. I will get an autometer gauge. Black Sun: my radiator air damn is there, but really mangled from speed bumps. I will replace it. I will check for air in the system as well. I am worried about a head gasket or cracked block/head. It has 97,000 miles on it. It has been supercharged for about 50,000 of those miles. The electric water pump does come on. It doesn't have the flow that I expected from a 55 gpm unit, but thought maybe the radiator was choking it, or there was air.
Thanks for all the help. Any more ideas will be appreciated. I will check into everything mentioned here.
M
my93gtdroptop
#12
  • Jul 15, 2005
  • #12
Also, does anyone else out there have a Meziere 55 gpm electric water pump? Mine seems to have a electric buzz when the thermostat closes, that sounds bad. Anyone else heard that? When I pull the radiator cap off and turn on the pump all I can see is a whirlpool sucking down. (It has an automatic trans cooler). It doesn't seem that strong, especially for a 55 gpm unit. I am worried that my nice, new electric water pump isn't working how it is supposed to.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 15, 2005
#13
  • Jul 15, 2005
  • #13
A stuck thermostat would keep the pump from flowing....
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
