I just got my car back from putting in new heads and it drove great for a few days, (other than the occasional hesitation from a sensor). Well, today, I get on it and slam into 2nd. I drove normal after that and noticed a hell of a lot of vibration. So, I tried a few different things. Revving above 3k just makes it vibrate. The higher the RPM, the more it vibrates. I revved it in neutral at a stop and while rolling. Still vibrates. I put in in gear while rolling at higher speeds and the vibration almost goes away when I put the clutch in while rolling. Meaning that the vibration does not occur at idle, rolling or not. As soon as I put in back in gear, it vibrates. Even at 15 MPH in 1st gear it vibrates. I just put in a new Professional Products balancer 3 days ago. The weight is still solid and in tact. I asked a good friend of mine which is a mechanic and he said it is almost 100% that it is my clutch/flywheel. This makes sense because is happened right after I abused it. And the clutch is about 3 years old with about 40k miles on it. It's a centerforce stage 1. Does this sound right to your guys? I just recently put in an aluminum driveshaft and it almost stopped the vibration I had before. It was down to a minimum. Any other things I should check before I buy new parts? I just don't want to get a new clutch and flywheel and that not be the problem. Do you think it is safe to drive if I dont go above 3k RPM for the next few days?
Like I said my rocker arm nut was just laying to the side of the rocker arm.
Let us know. Peace
Any idea what kind of stuff you can see in the clutch area if you remove the 'inspection' plate? Never done that before. Anyway keep us updated I really want to know if you fix this
