crickets???
  • Thread starter Thread starter notchman90
  • Start date Start date Nov 8, 2004
N
notchman90
87
long isle, ny
Nov 8, 2004
  • Nov 8, 2004
my clutch is making a wierd noise that sounds like a cricket. when i press down on the clutch the noise goes away. when my foot is off clutch its always there, and its loud!! Anyone have any idea what this could be, throw out bearing maybe?
thanks
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Nov 8, 2004
  • Nov 8, 2004
its the throwout bearing for sure...you can take it all apart and grease it up...but thats a lot of work for just that
bryanrevans
296
Chicopee,Mass
Nov 8, 2004
  • Nov 8, 2004
Do you have an adjustable clutch cable??I tightened mine down to where there was no play in clutcH fork.It would cherp like hell when it would idle in nuetral.The self adjustable linkage is worn so there was play on end of cable good luk!!
N
notchman90
87
long isle, ny
Nov 8, 2004
  • Nov 8, 2004
thanks for the replies, na i dont have an adjustable cable. Is it hard to grease up the bearing?
HISSIN50
34
129
Nov 8, 2004
  • Nov 8, 2004
the bearing should be sealed - not greasable. depends upon the manufacturer though. i personally would not want grease being flung around in there. a worn bearing retainer can also cause some noises.
but it sounds like the TOB and retainer should be looked at. many folks choose to dial in some preload to bandaid the problem.
good luck.
Cobra1894
196
Broken Arrow, OK
Nov 8, 2004
  • Nov 8, 2004
Thorwout bearing@!
04sleeper
2,674
14
89
Dallas, TX
Nov 8, 2004
  • Nov 8, 2004
It's the TOB. You could bandaid the problem for now but it will not get any better and needs to be replaced. Also when you replace it check for wear on the bearing retainer for grooves or uneven wear and replace it if needed. They sell a replacement steel bearing retainer for around $50 that seems to last longer than the stock one.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Nov 8, 2004
  • Nov 8, 2004
good luck.
exactly...but when you buy a new one or get one with a clutch set it is usually overflowing with grease...i guess thats what i meant
PNY PWR
522
Wichita, KS
Nov 9, 2004
  • Nov 9, 2004
Mine's doing it too, not very loud, just noticable to me. I'm gonna let it go for a while.
payupsucka
324
Keeping it grimy in Fall river MA.
Nov 9, 2004
#10
  • Nov 9, 2004
  • #10
thats funny every clutch i have put in the 2 5 0 mustangs i have had did that what was i doing wrong ?
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
2K
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
