Crooked Seat Problem
  • Thread starter Thread starter Street89GT
  • Start date Start date Apr 25, 2009
Street89GT
55
  • Apr 25, 2009
Hi All,
I recently removed the front seats and center console to give my interior a badly needed scrub down... After re-installing the seats and console the passenger seat seems to be sligthly mis-aligned. The Seat leans towards the door a bit and when the door is shut it makes contact with the door arm rest. The problem is it squeaks like crazy from rubbing the arm rest every time I hit a bump.
I took the Seat back out and tried adjusting the seat tracks to get it to align correctly, but the seat always slips back to that same position. Any ideas on how to get this seat to line up correcctly?
T1 3VOM
Maryland
Apr 25, 2009
  • Apr 25, 2009
When you took the seats out, did you take the tracks off of the seats?
Street89GT
55
  • Apr 29, 2009
John, Thanks for your response.
The seat was bolted to two slides. The slides were bolted directly to the seat with 4 bolts. When I removed the seat the slides remained attached to the tracks
T1 3VOM
Maryland
Apr 29, 2009
  • Apr 29, 2009
Not sure what to tell you. What happens if you bolt the back down first, then the front?
Does it make more contact when the seat is moved forward or backward?
90limited
276
Port Charlotte FL
Apr 29, 2009
  • Apr 29, 2009
Sounds like the track got out of wack... one track is one notch off from the other one. Just bolt in the front. The back should almost line up with the rear holes. If not, activate the adjustment lever and slide the tracks until they are even.
93 LX
3,081
Norwalk, CA.
Apr 29, 2009
  • Apr 29, 2009
maybe the floor board is cracked....
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Foxbody Driver's Seat Issues---Need Advice
  • 1992MustangGT
  • Mar 18, 2023
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2024
Scrapla347
M
  • mnky99
  • Sep 5, 2025
mnky99
M
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
