Crossed fuel lines?
  • Thread starter Thread starter jstang209
  • Start date Start date Apr 8, 2006
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Apr 8, 2006
  • Apr 8, 2006
Wat would happen if you crossed the send/return from the pump with the send/return lines from the fuel rails. If you dont understand what im trying to say.. IE Send line from pump connected to Return line from Fuel Rails, Then the Return line from pump connected to the Send line from the Fuel Rails.. I've been averaging about 8MPG!! and its not cool!!
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 8, 2006
  • Apr 8, 2006
how do you drive do you drive like your at the track cause that will eat gas fast.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Apr 8, 2006
  • Apr 8, 2006
naw i dont drive fast like im at the track lol.. i dont no what type of driving you would have to do to get my MPG..
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 8, 2006
  • Apr 8, 2006
I'll buy a 4 cyl notch or LX and trade you strait up. That would cure your 8 Mpg blues lol.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 8, 2006
  • Apr 8, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Apr 9, 2006
  • Apr 9, 2006
OR
?? another famous automoted response haha.. im just asking if neone noes wat will happen if you crossed the fuel line.. Would the car even start?
98CobraClone
592
Ripley, Ohio
Apr 9, 2006
  • Apr 9, 2006
Either way you would build pressure in the fuel system. Your feed lines would be 1/4" and the return lines would be 5/16". It wouldn't be optimal, but if anything, the engine would be starving for fuel, rather than just wasting it
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 9, 2006
  • Apr 9, 2006
Well if fuel went up the return line it would bypass the pressure regulator, not sure the car could even run.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
