crossmember mod for tremec
  • Thread starter Thread starter ONEBADPNY
  • Start date Start date Jul 8, 2006
ONEBADPNY
195
FREMONT, NEBRASKA
Jul 8, 2006
  • Jul 8, 2006
i put in a tko 500 awhile back and modded up the stock crossmember to fit it. moved the member all the way back to fit the tranny. now i just put in new crossmember bushing and poly trans mount and i have a rattle/noise coming from the crossmember. i get it while i am driving around 2300rpm or so sounds like a piece of metal vibrating on something. i took a malot and beat on things under the car and found that the crossmember is the problem. but i don't know what i need to do. i tack welded the member in place where i needed it but i am wandering if i need to take it back out and weld some more. thinking that may be where it is coming from. otherwise all bolts are tight so i don't know what else on the member could be making the noise.
Oh and no the member is not hitting the trans. plenty of room there i checked already. anyone have any other ideas or had the same thing happen?
GearHd6
459
Ashford, CT
Jul 8, 2006
  • Jul 8, 2006
Check and see if the front side of the mount is rubbing on the tailshaft housing of the tranny. I've seem them real close and i've seem them actually almost rub a hole through the tailshaft housing itself.
ONEBADPNY
195
FREMONT, NEBRASKA
Jul 9, 2006
  • Jul 9, 2006
i made sure it wasn't rubbing the tail shaft. so thats not it.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
