I replaced my airbagged and cruise control equipped stock steering wheel a while back. I started thinking that i wanted to keep the cruise control. I've hooked it up and tested the switches via the wires in the column , bypassing the old setup in the stock wheel. I was able to use the horn button in the new wheel by keeping the 2 wires needed coming up from the spinning contact type deal.
I came up with super gluing the 2 cruise control switches together. They fit perfectly in the ash tray after removing the butt putter outer. I drilled a hole toward the front to run the wires. I'll then run the 3 wires up inside the column and connect to the 3 wires that go up to the spinning contact gizmo.
I'll take some pics tommorow during the final install. Hopefully this might help someone who has or is going to install an aftermarket wheel and wants the cruise.
Here's a pic of the final product. i might make a cover at work to fit around the buttons to cover up those edges.
