Cruise Control Removal ?
  • Thread starter Thread starter Curse
  • Start date Start date Jun 21, 2005
Curse
791
El Paso, TX
Jun 21, 2005
  • Jun 21, 2005
I am relocating my battery to the hatch on my 89 GT. I plan on running the power wire inside the car; everything was going fine until the firewall. I could not figure out a way to run the wire through the firewall, so I looked at existing hole already at the firewall. None were big enough to fit my 1/0 welding cable through them. I think I can fit the 1/0 welding cable through the hole were the cruise control exits. I have the main part of the cruise control removed from inside the fender, the main problems I am having is with the cruise control cable and with the wiring harness for the cruise control. How do I separate the cruise control cable from the throttle cable? Do I have to break off the plastic housing holding the cables together? Were do the wires from the cruise control go to? I lose them at the firewall and can't seem to fine were they hook up to. The only vacuum line I have to plug is the one from the cruise control to the vacuum tree, right? If anyone can offer some guidance, it would be much appreciated. If it were up to me I would hack everything off, but a friend of mine wants it so I can go crazy on it. Thanks
Victor
Curse
791
El Paso, TX
Jun 21, 2005
  • Jun 21, 2005
Ok I figured out the cable problem, but still can't see were the electrical goes to. Anyone???
Curse
791
El Paso, TX
Jun 22, 2005
  • Jun 22, 2005
N/m
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
