Cruise not working
  • Thread starter Thread starter 90blue5.0
  • Start date Start date Sep 8, 2008
9
90blue5.0
266
Regina, Canada
Sep 8, 2008
  • Sep 8, 2008
I’m replacing the heater core in my ’90 this weekend and would also like to get my cruise working at the same time. Beyond the obvious fuse check what should I look for? What’s the common cause of cruise control not working?
For background, it always used to work, sometimes you would have to press the set button more than once but it was always good until one day it just stopped.
K
KGOFF
63
nj
Sep 8, 2008
  • Sep 8, 2008
vacume lines......
K
KGOFF
63
nj
Sep 8, 2008
  • Sep 8, 2008
http://www.veryuseful.com/mustang/tech/engine/images/88Stang5.0Vacuum.gif
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 8, 2008
  • Sep 8, 2008
Dump the codes and make sure you don't get a code 27 or code 29 - the VSS sensor is used by the cruse control.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
