I had to make my own wedge shims because I couldn't see paying so much for those either.
Now, not that I'm disagreeing with your statement, but where does Pro-motorsports state that their bump steer kit has "anything to do with the angle of the upper ball joint"? The only thing I found readily was:Opentracker said:I don't like that Pro Mo deal. I see no reason why a bump steer kit would have anything to do with the angle of the upper ball joint. Someone is trying to sell more parts.
A bold statement for sure, but it doesn't say that the bump steer kit is required or needed because of ball joint angle. I think many folks will recognize that lowering the upper arm can lower the car, which can cause bump steer issues.Pro-Motorsports Engineering said:The Bump Steer Corrector Kit when used with the Neg. Wedge kit produces the ultimate Mustang/Falcon front suspension.
HistoricMustang said:I do not use any of the aftermarket suspension stuff for reasons explained a bunch of times and created a lot of arguments.
The performance of my car at the track speaks for itself.
To have fun in the early models you do not need to spend all the big bucks. Put those suspension dollars into other performance items and have fun.
HistoricMustang
www.historicmustang.com
I read somewhere that the ProM bumpsteer kit should only be used with ProM's neg wedge kit. Anyone know about this (to save me a phone call to ProM)?
Got it!Opentracker said:Just giving my opinion on the question.
Yes, just bolting some non-adjustable parts on can't eliminate bump steer for every set up. If you end up with bump steer that you want to fix, go with something adjustable. Also, it seems to me that the aftermarket R&P units are the common culprit. I've lowered my car quite a bit, and I'm sure my original front springs are sagging, and I don't have any bump steer that I've noticed. I think that's probably why Historic doesn't have a problem, more so than smooth tracks. Historic hasn't put a R&P unit on his car. Tracks aren't all that smooth.Billgear said:First thiing, find out if you have a bump-steer problem. Set your car up on level spot and measure the amount of toe change you experience as your suspension travels up and down. Removing your springs and setting up some kind of measuring device would be nessasary. The Pro-motorsports bump kit is one size fits all, the baer trackers need to be dialed in to get rid of the bumpsteer. You will need to add or remove spacers tell you get the least amount of bumpsteer. Here is a pic of my setup for reference
Make sure all your suspension parts are in good condition, worn out bushing especially strut rod bushings can look like a bumsteer issue..
