curious
crazystang25
492
just curious as to how much a eaton off of an 03-04 cobra runs, found one a while back that had like 40k miles on it and the dude wanted $400 for it. decided not to get it though. sounded a little fishy to me at the time. looked at it and saw a few small nicks in the rotors themselves, but over all seemed to be in pretty decent shape, rotors and everything rotated just fine, didnt catch at all through the entire rotation of the assembly. nose assembly felt nice and tight no play at all in that area. the intake plenum had also been ported and was very smooth.
ya i just checked the price on that kit from tork tech and its $1900.00 without injectors, IC coolant reservoir, hoses or heat exchanger,or. upgraded fuel pump (which can be taken care of with a KB boost-a-pump). so its more worth gettin a non intercooled KB then adding the IC later on.
Idk about that. Here is a kit on ebay right now. http://cgi.ebay.com/ebaymotors/03-0...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
From what I can tell, has everything you need other than the tork tech kit, all for $1600. So that's $3500 for a complete intercooled kit vs. $3900 for the non-intercooled Kenne Bell http://www.kennebell.net/pricelist/SC-PRICELIST.pdf
And I've seen complete, or almost complete, minus a couple a hundred dollars of miscellaneous stuff, kits like this go for $1100 on ebay before.
Take it for what it's worth, but if it were my money, it wouldn't even be a choice. But hey, different strokes for different folks.
-Will
