Custom Autosound Disaster!
  • Thread starter Thread starter Brooklyn66
  • Start date Start date Apr 30, 2005
  • 3
First Prev 2 of 3 Next Last
mfp4073
387
Hells Ditch, FL
May 2, 2005
#21
  • May 2, 2005
  • #21
1320stang said:
But, MFP, the '65-'66 dash doesn't allow for the normal shaft type radio that fits into your '67. You have to hack the dash to make it fit and they still look like crap. The reason those piece of crap units are so high in price is that that's the only company that make 'em.
I thought the 65/66 openings were the same as mine? Is it a case of the opening or the post location?
jesset
17
#22
  • May 2, 2005
  • #22
The opening is cut-out in the dash and space is somewhat limited. I've seen so many mustangs cut the dash and just replace it with a regular unit that it almost looks normal. But for any person looking to keep the stock look without damaging their dash, the units that Custom Autosound makes are perfect. Yes they are little pricey and don't have all the features (Tremble???), but they work good.
1320stang
4,329
23
89
Edmond, Oklahoma
May 2, 2005
#23
  • May 2, 2005
  • #23
Both. The posts are raised up off center of the horizontal centerline and the bezel itself has rounded corners.
http://www.hammar.dyndns.org/radios/4TBZA.jpg
http://www.hammar.dyndns.org/radios/4TBZ.jpg
It was really made for the Mustang as it follows the contours of the dash, much like the '96-'99 Taurus oval radio.
Here's a more rare AM/FM radio:
http://www.hammar.dyndns.org/radios/F6TBZA.jpg
And the more rare 8-track that I believe hacks the dash:
http://www.hammar.dyndns.org/radios/T6SMZA.jpg
RGS0907
429
New Jersey
May 2, 2005
#24
  • May 2, 2005
  • #24
I'm hoping for decent MP3 decks to come out with two shafts that will fit the stock bezel & get away from CD's altogether. Am I dreaming or what?
mfp4073
387
Hells Ditch, FL
May 3, 2005
#25
  • May 3, 2005
  • #25
Several of the ones I have seen have adjustable posts, but not all. I have also seen different size opening plates (ie some fill my hole better than others).
what is the size of your opening?
The RF cd changers are some sort of best kept secret and will still work with any head unit via the antenna lead.
stangman67
294
connecticut
May 3, 2005
#26
  • May 3, 2005
  • #26
Just cut the dash and enjoy your sound. If you ever want it original, just put that patch panel in. Its not like our original cars are worth that much anyways. Make it how you want it because youll never make $ on a baisc mustang. I cut my bezel in my 67, even though it could be replaced much easier, and im glad i did! A good CD player install probably made it worth more in the end, but what do i care, Ive got 4x's the $ in this car than its worth.
63_Fairlane
215
Greenville, SC
May 3, 2005
#27
  • May 3, 2005
  • #27
Well, I guess I lucked out. I don't have to worry about this decision on my '65 project car. The previous owner already hacked the dash for a standard post stereo (incorrect offset). The original radio was long gone as the "new" head unit was a POS tape deck. I will probably just enlarge it to a standard DIN opening for more stereo options.
mfp4073
387
Hells Ditch, FL
May 3, 2005
#28
  • May 3, 2005
  • #28
I would say just the opposite. Hacking the dash on them is a PIA to fix. I would think a little extra effort now to not have to deal with it later would be well worth it.
1320stang
4,329
23
89
Edmond, Oklahoma
May 3, 2005
#29
  • May 3, 2005
  • #29
Yeah, a '67 is easy, buy a repo bezel and hack away. The pathc panel doesn't line up exactly, just like the repop fenders and doors. Original metal is ALWAYS better than repop if its in good shape. And I'd have to disagree about a couple of things Stangman said. Restored cars like my A-code coupe are apparently bringing in the $16k-$20k range if they're done properly. And as far as having 4x what it's worth in your car, are you counting the money that you have spent on stuff, but have now replaced? I know guys that have had 11 second Camaros that they've spent $60k on. But they've gone thru 4 intakes, 5 or 6 carbs, replacement axles and rear ends, 2 or 3 engines, sets of heads, multiple exhaust systems, paint jobs... Point is, if they had been patient and spent wisely, they'd have a $35k 8 second car. Are you including everything you've ever spent on it, or just what you've spent on what's on it now? I'm not knocking you by any means, but I'm like MFP, a little forsight now could save a lot of frustration in the future, oh, and never say never.
19simmons65
214
Upper Marlboro, MD
May 5, 2005
#30
  • May 5, 2005
  • #30
MFP: Can the Sanyo MAR-B1021 be used with an amp? Aren't two more more preamp outputs needed?
mfp4073
387
Hells Ditch, FL
May 5, 2005
#31
  • May 5, 2005
  • #31
that unit has pre amp outs according to crutchfield.com. It will have one left and one right rca out (red and white). From there you run one rca cable to an amp and if its a 4 channel amp it will have 4 outs to speakers...2 front 2 rear (1 each left and right). If you want to run more amps, simply get an rca splitter and go from there.
Great68
691
Victoria BC
May 5, 2005
#32
  • May 5, 2005
  • #32
If I could pay someone to wire a detachable faceplate to work from someplace remote, so I could put the deck somewhere hidden, I would do it in a heartbeat.
DukeGnarley
597
Auburn/Ellensburg, Wa
May 5, 2005
#33
  • May 5, 2005
  • #33
a while back (before we lost everything) someone posted a link to a company that sold Pioneer head units with the face plate attached via a cable, i'll see if i can find the site again.
63_Fairlane
215
Greenville, SC
May 5, 2005
#34
  • May 5, 2005
  • #34
I didn't mean it would be easy to fix. Just that my car was already damaged by a previous owner so modifying it for a good stereo is not going to really hurt anything. Besides, my '65 is an elcheapo 6 to 8 conversion with little or no value to anyone other than me. Even so, I have not pulled out the die grinder yet, so I may look at other alternatives.
If it were a nice A, D, or K code car, there is no way I would hack the dash. In that type of situation, I would either leave it stock or really work hard on hiding the radio.
On a side note, I hid the head unit under the dash of my old Fairlane with the stock radio left in place. Of course, the Fairlane was a bigger car with more room to work and more places to hide things.
Brooklyn66
23
NYC
May 6, 2005
#35
  • May 6, 2005
  • #35
radio faceplate modification link
http://home.hccnet.nl/e.pilage/Radio_EN.htm
mfp4073
387
Hells Ditch, FL
May 6, 2005
#36
  • May 6, 2005
  • #36
good info, in addition, I just looked at several of the ones I have around here and they all have adjustable knobs. I think some of those ones like mentioned earlier have the same thing. its just not usually mentioned. The jvc I have here has a 1 5/8 x 5 1/8 inch opening. This is the JVC ks-r130. Also the sanyo that was listed in my previous post does list adjustable posts as one of its features. Someone measure the 65/66 opening for me!
1320stang
4,329
23
89
Edmond, Oklahoma
May 6, 2005
#37
  • May 6, 2005
  • #37
I'll try to tonight and post if I can remember.
Did you look at the rest of that guys site? Propane conversion!!! very cool (no pun intended)
1320stang
4,329
23
89
Edmond, Oklahoma
May 7, 2005
#38
  • May 7, 2005
  • #38
Okay, measuring the radio was easier than getting to the opening.
Adding for a tiny bit of clearance, the radio bezel is 3 7/8" x 2" with the corners being radiused somewhere from 3/16" to 1/4". I think it's actually a quadrent of an ellipse as the height seemed to have a 3/16" dimension from tangent to perpenducular to tangent where the width was 1/4" the same way.
GT2K
311
#39
  • May 7, 2005
  • #39
I did not bother to read this whole thread... but 3 words that go well together... "Custom, Autosound, Disaster". Read that again and repeat
1320stang
4,329
23
89
Edmond, Oklahoma
May 8, 2005
#40
  • May 8, 2005
  • #40
So I guess if you can adjust the posts, and squish the display together it will fit?
  • 3
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Upgrade Advice on an 89 GT Convertible NJ
  • SteakDad
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 18, 2025
limp
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
