So I finally got the motivation to do something this weekend. After realigning my hood and installing the hood pins I decided to make a custom throttle linkage. I got the directions from this site, http://www.fordmuscle.com/archives/2004/08/ThrottleLinkage/index.php. I didn't follow their directions exactly though. Instruction #6 says to cut the brake line to length. I thought it was a bit early to cut the brake line since I didn't have the rod measured to my desired length. So I did #6 last. I also used 3 grades of steel wool to polish the brake line and heim joints. Trust me, if you want the assembly to look great without painting go the steel wool route. I also plan to clear coat the assembly so it won't rust. I noticed a big improvement in acceleration and feedback without any sloppiness from this new linkage compared to the other one I had. Totally worth the $20 I spent on everything!
The Supplies
Close up of step washers and spherical rod end.
Close up on NAPA part #'s.
Before and after steel wool.
I used the chrome step washers the article suggested, but I bought them off ebay. Much, much cheaper.
This rubber washer was already there from my old linkage. I found two washers in my garage to stiffen this particular assembly.
Where it attaches to "bell crank" arm
The Supplies
