Cutting 6cyl Springs
  • Thread starter Thread starter blown65
  • Start date Start date Oct 20, 2008
blown65
1,938
Queen Creek Arizona
Oct 20, 2008
  • Oct 20, 2008
K, running these on my car for weight transfer, but I cant stand the front being jacked up like it is. Thought it might settle some but it really hasnt any.
I'm guessing maybe one coil will be enough, but anyone cut theirs and how much did you take out? I figure I need to drop a good inch to inch and a half.
zookeeper
3,415
63
109
Rogue River, Oregon
Oct 20, 2008
  • Oct 20, 2008
First off, you have a bitchin' Mustang. I just got finished watching your video at Redding, that car hauls! As far as cutting coils, one full coil gave me a 2" drop, but I chopped a 1/4 coil at a time just to be safe. It's time consuming, but it beats trying to weld parts of a coil back on when you realize you went too far. BTW, any chance you'll make it to Samoa dragstrip in Eureka next year? If so, let me know in advance, I live near there and would love to see that coupe run in person!
blown65
1,938
Queen Creek Arizona
Oct 20, 2008
  • Oct 20, 2008
Thanks for the heads up, Ill try a half coil to start then.
Ya, I want to go there, our local engine builder mentioned that track. I'd like to try it out once next yr.
Vinyl66
398
  • Oct 21, 2008
I've got 6 cylinder springs on the front of mine and it sits a bit too tall in the front as well. I've even cut maybe 1/4-1/2 of a spring already. I am about to cut another 1/4 coil off and see where that puts me.
If I were you I would not go more than 1/2 a coil on the first cut. 1 full coil is a big drop.
10secgoal
2,801
San Diego
Oct 21, 2008
  • Oct 21, 2008
Be very careful with the 6cyl springs. They don't have the same spring rate. I'd follow the above, and start at no more than a 1/4. I'm thinking about it, but it's hard. the car dives bad at our local track. No a lot of shut down. Probably the minimum.
blown65
1,938
Queen Creek Arizona
Oct 21, 2008
  • Oct 21, 2008
alright, ill cut a 1/4 and see what it does for drop. Doesn't really take that much more time to do more cuts.
zookeeper
3,415
63
109
Rogue River, Oregon
Oct 21, 2008
  • Oct 21, 2008
I know this sounds bizzare, but many years ago, I read somewhere that the Ford 6 bangers actually weighed more than the 289. I know it sounds impossible, but that would explain the car sitting too high with stock 6 cylinder springs.
10secgoal
2,801
San Diego
Oct 21, 2008
  • Oct 21, 2008
Yeah, I might be able to buy that. But the springs are noticeably taller, with smaller wire than the V8 stuff. Mine sits higher than it did with the V8 springs in the front also.
blown65
1,938
Queen Creek Arizona
Oct 21, 2008
  • Oct 21, 2008
Ya, I figured it would sit a tad lower myself, but then again I have alum heads and glass hood no battery, no power steering, so there is a little less weight up there than what was stock.
blown65
1,938
Queen Creek Arizona
Oct 22, 2008
#10
  • Oct 22, 2008
  • #10
Ended up 1 coil cut on pass and 3/4 on driver. Driver still ended up just a tad lower, but very little. Ended up almost 2" lower. Looks TONS better now.
iskwezm
4,159
20
79
Rowland Heights,California
Oct 22, 2008
#11
  • Oct 22, 2008
  • #11
no pics?????
blown65
1,938
Queen Creek Arizona
Oct 22, 2008
#12
  • Oct 22, 2008
  • #12
Looks ****ty without the caps on the wheels, didnt have them with me.
LW_horse
37
Sweden
Oct 27, 2008
#13
  • Oct 27, 2008
  • #13
Some I6 spring rates on page 7 in this thread:
http://forums.stangnet.com/565898-how-drag-race-your-classic.html
brianj5600
1,964
Middle TN
Oct 28, 2008
#14
  • Oct 28, 2008
  • #14
If you can find some that are 40+ years old they will not need cut. Mine is almost too low. I'll get a pic up soon. I have thought about getting spacers to lift mine up.
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
