Cylinder bleed down / upside down rings???
MR2_4_life
Please someone correct me if I’m wrong here…. When using the simple one gage bleed down test. You take the little one-way valve (Schrader???) out of the hoes connected to the gage… screw the hose it into the spark plug hole then connect the gage to the hose… after all of that… “by hand” bring the piston up to TDC on compression, mark the gage and start timing…. Right????
If I’m doing all that right…. Then I must have some major issues bigger than my over heating problem going on inside my motor…. Has anyone heard of an motor running w/ the rings upside down???
:shrug:
