So I'm new to how to calculate the entire compression thing. So answer me this. From a stock head (64cc) [correct me if I'm wrong] changed to a head with 58cc, what will the new compression ratio be?
Bore Size: 4.000
Gasket Bore: 4.100
Piston Top Land Dia: 3.965
Stroke: 3.000
Connecting Rod Length 5.090
Compression Height: 1.600
Deck Height: 8.200
Ring to Top of Piston 0.250
Gasket Thickness: 0.040
Valve Notches Volume: 4.00
Dome Volume: 0.00
Volume Head: 64.00
------------------------------------- :COMPRESSION RATIO: 8.760
calculation variables:
Piston to Deck: 0.010
Crank Throw: 1.500
Vol. Above Top Ring: 0.90 cc
Piston to Dec Vol.: 2.06 cc
Gasket Volume: 8.65 cc
Volume Clearance: 79.61 cc
Cylinder Volume: 617.78 cc
CID: 301.474
58cc head* 302 cid *
Bore Size: 4.000
Gasket Bore: 4.100
Stroke: 3.000
Deck Height: 8.200
Dome Volume: 0.00
Volume Head: 58.00
------------------------------------- :COMPRESSION RATIO: 9.393
Crank Throw: 1.500
Volume Clearance: 73.61 cc
CID: 301.474
