I have a 4.6 V8 GT 1997.
This is what I have so far: K&N cold air kit, SLP long tube headers, SLP X pipe and cats, Flowmaster Catback, BBK fuel pressure regulator & 70 mm throttle body.
In a few months time (once the missus is talking to me again
) I want to go for modified cylinder heads and cams.
I have modified a number of heads previously back in the UK a few years ago so I would like to do this job myself. My plan is to pick up a pair of stock heads form a breakers and spend time polishing and porting them. Once done I would also like to machine them to get the compression up a bit. I then want to add new cams - not wild but uprated. I have a few questions:
Is my plan ok, it is based mainly around keeping costs down and ensuring the car is still a good daily driver?
how much can I safely skim off the heads to up the compression, bearing in mind higher lift cams going in?
Any reccomendations for the cams?
Can I install Rhodes lifters? These allow you to go for really wild cams but will also let the car run as a smooth daily driver and retain a good tickover. These hydraulic lifters work in a similar way as the Honda VTEC does.
One final question: My car currently seems to run flat above 4500 - 5000 rpm, as if it was being starved of fuel - this was the reason for the fuel pressure regulator upgrade. This is now noticealbe since I installed the LT headers X pipes and new CAT's.
Should I take this to the dyno to get it remapped? Has anyone else experienced this problem? I would guess a visit to the dyno would definatley be in order after head and cam upgrades so I may wait until then.
Thanks in advance
) I want to go for modified cylinder heads and cams.I have modified a number of heads previously back in the UK a few years ago so I would like to do this job myself. My plan is to pick up a pair of stock heads form a breakers and spend time polishing and porting them. Once done I would also like to machine them to get the compression up a bit. I then want to add new cams - not wild but uprated. I have a few questions:
Thanks in advance
