AFR 165cc or 185cc cylinder heads for a 351w to 393 stroker engine? Should I go with 58cc or 61cc?
I have my original set of '69 351w cylinder heads. If I were to get these heads professionally ported to the max, would spending $1300 for AFR's be worth it? I understand I will lose about 40lbs of weight off of the front end. I have no money in the '69 351w heads. I already did a gasket match on the intake side and got a quote for $300 to finish the porting work. What do you guys think?
