  • SN95 V6 Mustang Tech
Damaged calipers?? HELP
  • Thread starter Thread starter CrazyCorey
  • Start date Start date Jul 26, 2005
CrazyCorey
30
Ontario, Canada
Jul 26, 2005
  • Jul 26, 2005
I did my brakes last and found out this morning that you are not supposed to compress the rear calipers piston the same way that you do the fronts ( like with a C-Clamp) but I guess that they get compresses by rotating the piston. Did I damage the rear calipers by not turning them back to compress them or can I just go back and do this step now. It has only been driven about 15 miles. Thanks alot everyone. Your help is appreciated.
98blueoval
507
North Carolina
Jul 27, 2005
  • Jul 27, 2005
I havent had to put brakes on my car yet..but from experiance the cars that i have worked on that the pistons needed to be turned while goin back in,would not go back in unless you turned them If ya brakes are workin ok..dont worry about it..lol
Lsredy2kstang
Look, I'm special, dammit
Woodstcock, Georgia
Jul 27, 2005
  • Jul 27, 2005
Yeah, I have not been able to compress then like that?
Are you sure did you use the same pads or put new on there?
I don't see how you could have gotten then on with new pads?
98CobraClone
592
Ripley, Ohio
Jul 29, 2005
  • Jul 29, 2005
I've tried pressing the front pistons and couldn't get it without rotating in...
like they said above, you'll be good with the same pads, but you wouldn't have been able to put new pads on and fit it all back on the rotor without doing something right
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
Brakes Need help ID’ing which brake lines and seals I need
  • AnthonyA1234
  • Apr 2, 2025
Fox 5.0 Mustang Tech Apr 14, 2025
limp
