  • SN95 4.6L Mustang Tech
Damaged Calipers?? HELP
  • Thread starter Thread starter CrazyCorey
  • Start date Start date Jul 26, 2005
CrazyCorey
30
Ontario, Canada
Jul 26, 2005
  • Jul 26, 2005
I did my brakes last and found out this morning that you are not supposed to compress the rear calipers piston the same way that you do the fronts ( like with a C-Clamp) but I guess that they get compresses by rotating the piston. Did I damage the rear calipers by not turning them back to compress them or can I just go back and do this step now. It has only been driven about 15 miles. Thanks alot everyone. Your help is appreciated.
96WhiteNight
303
Carlisle, PA
Jul 26, 2005
  • Jul 26, 2005
Im suprised you could push them in i couldn't with mine thats when i got the tool. Anyhow as long as your brakes aren't rubbing you should be good. If they are then i would go turn them back and bleed them off again.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
