  • SN95 4.6L Mustang Tech
Damn E-Brake
  • Thread starter Thread starter SRT Handz
  • Start date Start date Apr 27, 2005
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Apr 27, 2005
  • Apr 27, 2005
CAn some one tell me how to adjust it and make it tighter?
GDawg
1,469
Nevada
Apr 27, 2005
  • Apr 27, 2005
Did you have the (old) parking brake recall done? After mine was "fixed" it became a lot tighter over all (but the handle is now loose side to side. Figures Ford can't fix one thing without screwing up something else.)
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 27, 2005
  • Apr 27, 2005
did you replace calipers on this car or any other parts in the e brake system and not put the pin in the tension relese hole in the parking brake control.
if this is the case remove the console and remove the parking brake control unit (handle and mechanicalsthat it attaches too) withthe unit on a bench you maybeable too pull the tension spring all the way back and stick a pin in the hole too lock it untill the cable is attached.
Mike97gt
it doe snot
10,633
Apr 27, 2005
  • Apr 27, 2005
HEY watch it. i am one of those service techs you claim can't fix one thing without screwing up another
hognutz
1,940
albany, oregon
Apr 27, 2005
  • Apr 27, 2005
I know there is not adjustment on mine. I dont' know if 98 was any different.
hognutz
1,940
albany, oregon
Apr 27, 2005
  • Apr 27, 2005
If your a tech what is the trick to getting the ebrake cables back on the rear calipures.
I put MM lower control arms on and had to flip the cable brackets. I had the worst time getting the cables back in place on the calipures.
Is there a trick to this?
97gtconv.
244
Lock Haven, PA
Apr 27, 2005
  • Apr 27, 2005
i took a look at mine and there's no adjustment, it's put together loosely. mine vibrates alot but there's nothing i've found to cure it. i've never heard of a recall on it or anything like that.
merc123
420
North GA
Apr 27, 2005
  • Apr 27, 2005
Pull the brake up and drive backwards. (Seriously, it worked on my cougar).
crazynorwegian
20+ Year Stangneter
Nov 6, 2003
267
azusa, ca
Apr 27, 2005
  • Apr 27, 2005
I had mine replaced for the recall last week, mine also moves side to side a lot now, and is also not as smooth when you pull it up. I liked the defective one better. although it did slip one time in my friend driveway, and the car rolled into my friends brand new 03 gt
CaliLifeStyle
625
Oxnard, CA
Apr 27, 2005
#10
  • Apr 27, 2005
  • #10
What years and models did this recall involve?
Mike97gt
it doe snot
10,633
Apr 27, 2005
#11
  • Apr 27, 2005
  • #11
the trick is too pull the cable end with a vise grip and slip it into the caliper..
thats how i do it.
Mike97gt
it doe snot
10,633
Apr 27, 2005
#12
  • Apr 27, 2005
  • #12
your cougar must have had rear drums then. the mustang has no e brake adjustment. but you have too put a pin in a slot inthe rear e brake controler before you relese the cables. or you may have a weak e brake
GDawg
1,469
Nevada
Apr 27, 2005
#13
  • Apr 27, 2005
  • #13
All due respect but why did almost all of the cars that had the e-brake recall done have the same side to side problem I described? And I mean there were tons of people that complained about this a few years ago when the recall first came out.
hognutz
1,940
albany, oregon
Apr 28, 2005
#14
  • Apr 28, 2005
  • #14
thats how i do it.
Is it kind of a pain in the ass for you or is it easy. since there is no ajustment the second one wa just a pain in the ass. I mean I was laying on my back under the car so my leverage may have sucked but it seemed to took alot of energy. I must just be a .
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Apr 28, 2005
#15
  • Apr 28, 2005
  • #15
Drive backwards slowly, not too fast and apply the brakes hard a few times. Wait! This won't work on disc brakes. Used to work with drums though.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
General karthief
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
