Damn E-Brake
SRT Handz said:
CAn some one tell me how to adjust it and make it tighter?
Did you have the (old) parking brake recall done? After mine was "fixed" it became a lot tighter over all (but the handle is now loose side to side. Figures Ford can't fix one thing without screwing up something else.)
did you replace calipers on this car or any other parts in the e brake system and not put the pin in the tension relese hole in the parking brake control.
if this is the case remove the console and remove the parking brake control unit (handle and mechanicalsthat it attaches too) withthe unit on a bench you maybeable too pull the tension spring all the way back and stick a pin in the hole too lock it untill the cable is attached.
MikeZ28 said:
HEY watch it. i am one of those service techs you claim can't fix one thing without screwing up another :p
If your a tech what is the trick to getting the ebrake cables back on the rear calipures.
I put MM lower control arms on and had to flip the cable brackets. I had the worst time getting the cables back in place on the calipures.
Is there a trick to this?
I had mine replaced for the recall last week, mine also moves side to side a lot now, and is also not as smooth when you pull it up. I liked the defective one better. although it did slip one time in my friend driveway, and the car rolled into my friends brand new 03 gt
the trick is too pull the cable end with a vise grip and slip it into the caliper..
thats how i do it.
All due respect but why did almost all of the cars that had the e-brake recall done have the same side to side problem I described? And I mean there were tons of people that complained about this a few years ago when the recall first came out.
thats how i do it.
Is it kind of a pain in the ass for you or is it easy. since there is no ajustment the second one wa just a pain in the ass. I mean I was laying on my back under the car so my leverage may have sucked but it seemed to took alot of energy. I must just be a :taco:.
