Dash Swap question
NewToFord
318
CT
I have a 90 GT donor car. It has the black and red dash that is mint. I want to put it into my 93 4cyl conversion car. I plan on running the 93 V8 computer harness etc. Both cars are auto, but I plan on putting in a 5spd. My question is will the 90 dash work fine, and can I still just use the 93 wiring in it? I would think that the dash swap is mostly just cosmetic, and the wiring would stay in the frame of the dash? Also both cars have the fuse panel under the dash on the drivers side.
Not hard at all. Just make sure you have the proper screwdiver with either a nut-driver head or a torx bit.
You'll also need either a stubby phillips head screwdriver or flexible head screwdriver for the two screws on top of the gauge cluster.
Remove the armrest and then remove the entire center console and then the dash will come out after you unscrew the 50 or so screws holding it on
Can be done in a couple hours.
Might want to do the heater core while you are there
